Layout does not save properly
Using Studio 4.20.0.2 and Windows 10 Pro 64-bit, I've noticed that the layout scheme doesn't save. I recall from another thread that sometimes Windows has an issue with setting the target folder or file to "read only," so I went to C:\Users\Me\AppData\Roaming\DAZ 3D\Studio4 and found the layout file. It's okay.
However, the Studio4 folder is read-only and I can't reset it to being read-write. What's driving me nuts is that I just installed Windows 10 today on a brand new hard drive and it's already messing with me.
Any ideas how to handle this? Could I be looking at the wrong folder or file?
  • GranvilleGranville Posts: 702
    No ideas, but it is driving me nuts too!
  • Richard HaseltineRichard Haseltine Posts: 111,382
    This is a known issue, discussed in the release therad among other places. The current public Build has a fix that seems to eb working, if that continues to be the case the General Release will probably be updated soon. In the meantime you can manually create the files used to save the session layout (as empty files) and DS will then be able to overwrite them on the exit.
  • externalexternal Posts: 7
    Possible solution:
    Create these six files (just make normal text files and change the file extension):
    actions.dsx
    customactions.dsx
    layout.dsa
    layout.dsx
    menus.dsx
    toolbars.dsx
    Close Daz and put all these empty files in
    C:\Users\[UserName]\AppData\Roaming\DAZ 3D\Studio4\
    C:\Users\[UserName]\AppData\Roaming\DAZ 3D\Studio4\user layouts
    It should work then, although it did for me, YMMV
    Not the .dsa file, just the .dsx files.
  • The BrigThe Brig Posts: 89
    external said:
    Possible solution:
    actions.dsx
    customactions.dsx
    layout.dsa
    layout.dsx
    menus.dsx
    toolbars.dsx
    Oh, external, you delightfully devious devil, you. Worked for me, too. Consider yourself high-fived all to hell and back.
    does that mean I delete the ones that are there?
    Okay. I got it! Thanks. It worked. I did overwrite my actions, but I needed to start over anyway. It was getting clunky.
    Thanks!!yes
