Odd dForce visibility issue
Perhaps this is unique to me but I have an annoying problem with dForce. I usually select everything in a scene that I don't want to influence a dFroce drape by turning off "Visible in Simulation" (I wish that was off by default because going through that exercise for every scene is a PITA). Anyhow, I have noticed that occasionally I want to re-enable a prop to interact with a drape so I toggle "Visible in Simulation" back on again. Only to find that the cloth drops straight through the prop. No matter what I do I can't make it visible to dForce. The only option is to delete the prop completely and re-load it again. Now it will interact with the cloth simulation.
  • Richard HaseltineRichard Haseltine Posts: 111,792
    Just doing that within a scene, in a single session? I just tried with a plane and a cube in the General Release and couldn't reproduce the issue setting the cube's visibility to simulation on and off.
  • marblemarble Posts: 7,500
    It happens for me in various scenes and multiple sessions. The props are usually furniture which I normally switch off for simulation but sometimes I need to re-enable so that the chair will collide with a dress. It has happened too many times to be a freak occurance - I delete the chair and reload it and it can now be visible to dForce. I should add that I'm still on 4.15 so it might have been fixed by now.
    edited March 2022
    Yeah, it happens with both props and dForce enabled cloth. I have a Duvet in a reloaded scene with a wooden bed frame and have had to delete and reload both in order to get them to be dForce enabled. I don't know how things like this can happen when I have not updated DAZ Studio for a year or more and it used to work fine.
    Post edited by marble on
