Please Help - Creating A Forming Prop
Dark45
I've been trying this off and on for a year now. I really hope that someone could help me figure this one out.
I have made some Anthro models and I'm using Look At My Hair to create the fur for them. LAMH creates a prop, I want to fit this prop to my models as a figure instead of a prop so I do not have to reload it for every render I make (would save a ton of time).
I've been trying to use the Transfer Utility to do this but it doesn't work quite right, it treats it more like clothing kinda. I'm just not even sure where to start anymore. As you can see it gets clump or stretches when I move a limb and it clips into the model or moves off of the models texture.
Thank you in advance if anyone can help me understand how to do this.
Haven't tried this with a hair suit, however for clothing that is an area which normally requires a pJCM to be made.
In essence you create a replacement partial Joint Control Morph to replace the generated morph in the hair/clothing - so it must be named the very same.
