Needed help with facial details on Genesis 8.1
Hi, I'm having an issue where facial detail on genesis 8.1 is a little off around eyes area.
I suspected that it was RN Minto face detail since I was temper with it makeup and mat's
before moving to other things. it was the last thing I did to the facial feature from I recalled.
Also when selected remove face detail, it worsen the effect. Apply face detail did nothing
The inner eyelid on right side rotated out slighty and the upper eyelid dented downward.
On the left side, inner eyelid rotated in slighty and the epicanthus are too close to the
lacrimal. I'm assuming that how the left side is but the right side are just buging me the
most. Is there a way to fix this since there's no dial I can tweek this effect and there
is no setting I can change it back to before as well. Thank you in advance for every replies
and for put up with my broken english.
Also, I know that rarestone have move on from this platform so if this request is imposible then I do understand.
It just that I have spended the last hours create a new G8.1 and going through all the morph and detail that
previous model have and it still not even look close to it. Meanwhile if I can just fix this one thing then I'm set.
