Required Products?
TwistedBeautyTwistedBeauty Posts: 21
I've been looking through the Daz catalog and I'm a little confused about something. If a figure says 'required products' Victoria 6, Stephanie 6, Aiko 6, etc. But in the 'Compatible Figures' area it says Genesis or Genesis 2, does that mean I still need the other figures?
  • Tramp GraphicsTramp Graphics Posts: 2,433
    Yes. Victoria 6, Aiko 6, and Stephanie 6 aren't figures. They're character shapes for Genesis 2 Female, and form the basis for many other characters.
    It's probably best to ask specific questions about specific items...there are some were only one of the required packs is needed and some where all of them are needed.
  • TwistedBeautyTwistedBeauty Posts: 21
    I see. Thanks for the answers.
  • LeanaLeana Posts: 13,499
    A few basic rules:
    If a character lists V6 as a required product it means that it uses at least a part of V6 (morph at some degree, or UVs). So V6 is indeed required if you want to use the character.
    If clothes or hair list V6 as a required product then it usually means they will have special morphs to support that particular shape. You can use the clothes or hair with G2F if you don't have V6.
    If an environment lists V6 as a required product then it usually means that it includes poses for V6. The environment will work perfectly without V6, the poses might need to be adjusted if you use them on a base G2F.
    Oh, that's incredibly helpful Leana. Thank you.
