I have issues with creating Morphs....
Thomas WindarThomas Windar Posts: 272
So I used Hexagon to create a special toon morph for Genesis 2 Female. I followed this tutorial, but the rigging of the figure is always messed up. http://www.daz3d.com/forums/discussion/6483/
Here is what I do:
1. I exported the G2F model into Hexagon with the Hexagon Bridge option.
2. I made my desired changes to the model in Hexagon.
3. I bring it back to DAZ Studio with the DAZ bridge function of Hexagon.
4. I apply the morph on the figure.
5. I dial the morph to 100%.
6. I take the Joint editor > Edit > Adjust Rigging to Shape > Check the Adjust Orientation option and and Accept.
7. Now the figure seems to work correctly. However now the problems start.
8. I got to the Parameter tab, select Edit Mode and select ERC Freeze on the Morph I made.
9. I make sure to UNCHECK the "Restore Figure Rigging" like the tutorial says.
10. I click accept. Now the whole rigging gets messed up.
11. If I try to save the morph - upon loading the rigging of the figure is messed up again. The morph doesn't modify the rig...
I don't know what to do now.... Do I select Memorize Rigging after I adjust it to the shape? If I do that, the Geografts get messed up....
Anybody could tell me what I am doing wrong? Is the tutorial missing something? Is this a program error?
I am using The 4.8 DAZ Studio beta, so maybe its a program error... but I am probably doing something wrong.
  • Richard HaseltineRichard Haseltine Posts: 112,059
    Don't uncheck restore rigging - the rigging will be adjusted by the morph after freezing so it should be put back i its base state.
  • Thomas WindarThomas Windar Posts: 272
    Thank you, that fixed my problem.
    I knew I was doing something dumb.
