Solved.......installed 4.20
Rufus CoppertopRufus Coppertop Posts: 178
All of a sudden, I can't select anything in the Viewport Window. I have to click through the list on the Scene Pane.
Does anyone know of a solution? It seems to have started when I tried to use the bone shaped tool.
CORRECTION - I can select and translate and rotate an entire figure, what I can't select is an arm or leg or head.
Problem solved by installing 4.20
Post edited by Rufus Coppertop on
  • felisfelis Posts: 6,523
    How does your Tool Settings look for Universal tool?
  • I don't know. I've always just clicked on the tool and used it.
    I've just installed 4.20 and that seems to have solved the problem. For future reference though, what do you mean by "tool settings for universal tool"?
    Good you got it solved.
    If you activate the Universal Tool, you can click Windows > Panes > Tool Settings.
    All tools has some settings, and for some tools the tools settings is highly needed. Panes that you use frequently can be docked for easier access.
