How to see existing dForce influence maps?
I am working with a piece of dForce clothing that clearly has a dForce influence map applied because some parts of the mesh will not simulate, even though the surfaces all have "visible in simulation" turned on and dynamics strength is 1.0. But I don't know where to see an existing influence maps included by the product developer? In particular this is SY Fantasy Weat Megapacck Bra 02, but this is a general question about any dForce product with weight maps already "built in" somehow. There's no Modified Weight Node shown, so how can there be a dForce influence map, and how can I access it and alter it? I feel like I'm missing something obvious about how to see existing weight maps applied to objects. It's not listed in the Node Weight Map Brush tool, and I can't think of where else to look.
  • Richard HaseltineRichard Haseltine Posts: 111,805
    Add a dForce Modifier Weigth Node from the Create menu and you will have access to the existing map(s) - the node is for selecting the maps for editing, however they belong to the dForce item itself and don't go away if you remove the access node.
  • thoreandanthoreandan Posts: 152
    Ah, thank you, Richard!
