Help Needed, Morph Dials Error [urgent]
Yonas AngYonas Ang Posts: 108
I have severe error with several of my morph dials.
Pic attached for more details.
There are duplicated dials on my DAZ Studio, I don't know where they came from, I never modify them myself.
These 2 dials have (2) in front of their dial name/label.
(2)Pupil Slit
(2)Pupil Dialate
When I open "Parameter Setting", both of them have PHM dials, and the ordinary ones "Pupil Slit" and "Pupil Dialate".
If I change the "Name" on the "Parameter Setting", to either "PHMPupilsDialate" or "Pupil Dialate", "PHMPupilsSlit" or "Pupil Slit", the morph become messed up and not working properly.
I've tried reinstall Genesis 2 Female Starter Essential and the G2F Head Morph. Bear no fruit, still got the error above.
Now whenever I try to modify both dials, value remain <?> but they are working(partly, since I can't adjust the exact value number for negative value)
Anyone, please help me, I can't do my project at this rate.
EDIT: I've found the source of the problem, it seems Actual Eyes 4 is the source. Actual Eyes 4 contain both morph, and poorly named so it's make DAZ Studio think both are the same as G2F Pupil Slit and Dialate morph.
837 x 536 - 309K
Post edited by Yonas Ang on
  • Richard HaseltineRichard Haseltine Posts: 112,037
    Open the pane's option menu - right-click on the tab or click the lined button in the top corner. If it is checked, uncheck Consolidate Properties. You should now see two sliders with the same label, relabel one of them and the problem should go away (and you can turn Consolidate Properties back on).
  • Digital TouchDigital Touch Posts: 189
    edited April 2015
    Thank you for the solution.
    Post edited by Digital Touch on
  • Yonas AngYonas Ang Posts: 108
    edited April 2015
    Thank you for the answer. Problem solved
    Replied with wrong account above, sorry.
