Possible to make a follower morph always visible?
So if you create custom morphs on an addon item that matches the name of a morph on the G8F figure, it will automatically link those morphs to the G8F morph and will dial in sync with that morph.  It will also set it to hidden by default, even though the checkbox for hidden isn't checked. That's all great, but is there any way to force one of those morphs to be unhidden all the time?   I've seen some products that have the jcms unhidden, so it seems like it might be possible but even opening up the morph dsf in notepad++ I haven't found any way to force it.
In this specific case, I made an eyelash morph that was linked to the eyes_closed morph, and they move in sync as intended, but I also want the morph slider to still be visible so I can adjust it on it's own for specific cases if needed.  I'd rather not have to show hidden morphs every time I want to do this.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    You could add a second proeprty that isn't hidden and controls (ERC Add) the actual morph.
  • FalcoFalco Posts: 269
    Ah, that's a good idea for a workaround. Thanks.
