How to use HDRI Lights pack
Hi i bought this item, but i did not understand how to use it.
https://www.daz3d.com/luxreal-hdri-lights-pack
i thought it was simplier. i open the enviroment, then i click on the light preset, bau i can find anything that shows me that the item is working. Any help?ù
Thank you
  • felisfelis Posts: 6,593
    You can only see an HDRI in Iray preview or actual Iray render.
  • ShimamuraShimamura Posts: 70
    thank You felis. but how i can sets this light. in the description the developer said i can rotate the dome, for example, but i can't see, in my render setting, as happens when i use an hdri enviroment, the dome.
  • Eggs ActlyEggs Actly Posts: 168
    You can access the dome rotation from the Environment tab in your scene.
  • barbultbarbult Posts: 27,631
    The product says it has two dome visibility presets. If you want to see the dome in your render, turn the dome visibility on.
  • If its possable to have a HDRI  dome visable.
    why the hell would they have it turned off by default
    so much I dont understand
    Thank you guys. Finally i solve the problem. Turned the dome as visible, and start to work with this good product.
