issue in Body Chains 3 for Genesis 3 and 8.1 Females
ironcheeseironcheese Posts: 78
Hello, I have purchased the "Body Chains 3 for Genesis 3 and 8.1 Females" by Sshodan.
When I try to fit any of the Genesis 8.1 Female items in the purchase to a Genesis 8.1 Female, I get the error "You have chosen to fit an unsupported item to the figure", as if the itemfor G8F was not for G8F.
Then if I inspect the product, the node name in fact shows a reference to G3F, for example "Genesis3Famle_StoneChain_Chest_210819".
This is true for almost all of the Genesis 8.1 Female items in the purchase, a few work as usual.
I have opened a ticket, but maybe if Sshoban reads these forum posts will be easier to solve this one...
is there anything I can do to fix the issue myself or do i need the vendor?
Thank you
280 x 233 - 21K
488 x 303 - 35K
Post edited by ironcheese on
  • felisfelis Posts: 6,503
    I would assume that there are 2 products, one for G3F and one for G8.1F.
    Are you using the right?
  • ironcheeseironcheese Posts: 78
    edited March 2022
    Yes, I am using the one in People/Genesis8F and I keep G3F and G8F in two separare libraries. I also tried swapping the two folders (in case the vendor had swapped them by mistake) and also I have redownloaded the product from scratch: same results.
    What happen if you in Scene Identification change it to G8F instead of G8.1F?
    yep, just did it ... that was the issue... thank you
