4.14.010 pro trouble with RTX 3050 - SOLVED
mattoceanmattocean Posts: 25
edited March 2022 in Daz Studio Discussion
Hello,
please help me I am confused. I got a RTX 3050 yesterday and since installed the card Daz Studio won't render. I have installed the Studio Driver 511.65. I unchecked the CPU fall back option (tried with checked on).
On a simple scene rendering working fine. On a complex  scene with room and two people the render starts but interrupt itself sometimes rendering is starting but stops after 20 sec.
The logfile says:
2022-03-05 15:34:46.580 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 1485 textures, 8 lambdas (1 unique)
2022-03-05 15:34:46.610 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (10 light sources with 22 triangles, 1 instance) took 0.000s
2022-03-05 15:34:46.611 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
2022-03-05 15:34:46.619 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
2022-03-05 15:34:46.621 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
2022-03-05 15:34:46.622 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
2022-03-05 15:34:46.622 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
2022-03-05 15:34:46.623 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
2022-03-05 15:34:46.623 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
2022-03-05 15:34:46.629 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using no convergence estimate.
2022-03-05 15:34:46.629 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
2022-03-05 15:34:46.635 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
2022-03-05 15:34:46.635 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
2022-03-05 15:34:46.638 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No device specified or usable
2022-03-05 15:34:46.638 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 0 device(s):
2022-03-05 15:34:46.638 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2022-03-05 15:34:46.638 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No worker to render with: aborting render
2022-03-05 15:34:46.638 Iray Render error: Internal rendering error.
2022-03-05 15:34:46.795 Saved image: C:\Users\user\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2022-03-05 15:34:46.797 Finished Rendering
2022-03-05 15:34:46.812 Total Rendering Time: 31.91 seconds
When I load just one figure without any background the rendering is working. The FurMark test detect the GPU and doing the test without any problem.
Does anybody has any tip what to do? Install new Daz or display driver?
Thanks.
Post edited by mattocean on
  • SpaciousSpacious Posts: 481
    This line "2022-03-05 15:34:46.638 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No device specified or usable"
    Either your GPU is not selected in DAZ to use, or there's something wrong with the driver or the card itself.  Did you reboot your machine after installing new driver?
  • frank0314frank0314 Posts: 15,100
    As @Spacious said, it sounds like you don't have the GPU selected in DS but defenitly install the newest driver for your card.
  • mattoceanmattocean Posts: 25
    The card is selected in Daz and the FurMark Test detects the card and running fine. Other programs like games using the card without any issue.
    Ok, it seems that I figured out and now is working...
    First I cleaned the SSD where Windows storing the swap file, I only had 15 gig free space, now I have about 50 gig free space, I disabled in the installed plugin list the 3Delight Renderer and figured out that one of the character SubDivision Level was set to 2, I changed this value to 1. I disabled CPU Fall back, render the scene only with the graphic card.
    I am running Daz Studio 4.14 pro and the latest Nvidia Studio driver.
