Custumizing DAZ items (paint, sculpt) workflow
PschelfhPschelfh Posts: 261
I've been looking at software to customize items (add more detail to humans and props, add wear, dirt, weathering,...).
Basicaly something that allows me to paint to UV's and/or sculpt detail to meshes while seeing the result in 3D in realtime.
So far I found :
- Substance painter (only painting, easy to use, but uses PBR materials, which will be more difficult to translate back to DAZ).
- 3D Coat
- Mudbox (most expensive of these, but this is last year you can buy a full license before it goes monthly)
- Blacksmith3D (least info on the net, but seems to be well integrated in the DAZ/Poser workflow)
It's a bit too much to learn each of these 4 inside out from the demo's, so any help or experience with these programs (and how well they talk to DAZ Studio) is appreciated.
Thanks,
Peter.
  • Ghosty12Ghosty12 Posts: 2,092
    edited April 2015
    There is Sculptris if that is what you are looking for as well and is I would say is the free version of Z Brush since both programs are made by the same company but Z Brush having more features and costs a lot.. But they do have a paint section not tried it myself more into the morph side of things..
    Post edited by Ghosty12 on
  • Fragg1960Fragg1960 Posts: 363
    ZBrush can do all those things you want, but not cheaply or easily. It talks to DAZ extremely well.
    After years of playing around with Studio, I read up on the program and saved up and bought ZBrush a couple of years ago. Frankly, it has a rather non-intuitive interface and you will have to devote significant time to reading how to do things, but I now use ZBrush to model my characters rather than the sliders in Studio. I export the model into ZBrush, do my custom morphs and then send it back into Studio as a morph slider. I even sculpt my own props (to practice sculpting) and use them in Studio as well. Even after all this time, I still don't know how to do some things in the program, but I'm learning as I go. Steep learning curve and price ($$$) so you'd better be committed to learning to sculpt (and reading and watching online tutorials)to justify the expense, otherwise it's a waste of money.
    Sculptris may be a better alternative (as the other responder said above), it kind of ZBrush Lite (and free).
  • LycanthropeXLycanthropeX Posts: 2,287
    Zbrush, def my go to prog for painting and adding morphs, fairly easy to learn once you get used to the interface... but not cheap... unless you do what I did, win it in a contest
