Animation: How to keyframe all limbs at once?
Hello,
I've been trying more animation, and I often prefer to use the Active Pose tool, though can sometimes be unpredictable in which limbs it moves.
However, if I try adding a keyframe to a character or anything with multiple limbs (like shoulder, to arm, to hand), the keyframe is only added to the active selection (even if I highlight multiple limbs).
Is there a way to add keyframes to multiple limbs at once (like the whole hand and fingers)?
Thank you!!
  • benniewoodellbenniewoodell Posts: 2,001
    Absolutley! I always go in the scene tab, highlight the top root of whatever area you want the key added to everything (like shoulder or even the character name if I want everything keyed), right click and select all children, then I go and click set key at the bottom.
  • GordigGordig Posts: 10,810
    At the bottom of the timeline, next to the key add button, change the dropdown to "node recurse" and the key add button will add a key for all child nodes.
    433 x 179 - 5K
    Ugh, so simple. Thank you!!!
  • marblemarble Posts: 7,500
    All this time and I wasn't aware of that! Thank you.
