Drag and drop Genesis poses in to Animate2
One week ago I purchased Animate2 and I try to get familiar with it, but........
Why can't I drag and drop poses from Genesis in to Animate2?????
I have no problems with G4 and M4 poses.
I use Studio 4.7 Pro
M4 and V4 poses are in Poser format (PZ2), but the Genesis ones are in DAZ Studio format (DUF) so that is probably why they wont work.
You can probably convert the DUF to PZ2, but I don't know how to do that off-hand, but I will look for you.
You can convert DUF poses to PZ2 using the 'Create Poser Companion Files' from the drop-down menu in the Content Library pane.
Select the DUF file that you want to convert in the Content Library, then select the 'Create Poser Companion Files' from the drop down, or you can select all DUF files in that folder.
Select 'Use this Library and File extension ' change the drop down to PZ2, and click Accept. they will appear in Poser Formats, Pose, DSON Conversions.
Thanks JimmyC_2009........the conversion did work :-).....but I still cant drag that converted pose in to animate2.
Not in the master track nor in a subtrack.
B.t.w...I also converted the figure....but that did not help.
