DSON Importer for Poser , do I need it if I do not have Poser application on my system?
rampart_1576840087rampart_1576840087 Posts: 504
I do not have the Poser application
I have read this is necessary in some situations to use poser files -> "DSON Importer for Poser"
If I don't need to install this I would appreciate a link or a quick message of what to do. I will not install it for now, until I find out more what to do.
These are message get when I try to install them via DIM.
Install Manager cannot find a required path. The package for "DSON Importer for Poser (Win 32-bit) Public Build +Beta+" requires that the installed path for "Poser Pro 2014, 10, Pro 2012, 9 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Install Manager cannot find a required path. The package for "DSON Importer for Poser (Win 64-bit) Public Build +Beta+" requires that the installed path for "Poser Pro 2014, Pro 2012 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
  • prixatprixat Posts: 1,627
    You're right, you don't need it.
    It's only for Poser 9+ users who want to import the newer DAZ items.
