can't load genesis 2
lindanslindans Posts: 99
I have just decided to start trying to use genesis but not had much luck loading her, I get the following message 'NoneType' object has no attribute 'NumVertices' Genesis - Poser pro 2014 any ideas or advice? I was hoping most of the problems would have been ironed out by now>
  • Richard HaseltineRichard Haseltine Posts: 111,348
    So, you are using Poser Pro 2014 and the DSON Importer? Did you install both the core Genesis 2 Female Starter Essentials and the Genesis 2 Female Starter Essentials PoserCF packages? Which icon are you using to load Genesis 2 Female?
  • lindanslindans Posts: 99
    I installed both the essentials and poser cf files
    Where is the Data folder? Is it in a folder that also holds a "Runtime" folder?
    Yes it is
  • frank0314frank0314 Posts: 15,098
    If the data folder is inside the runtime folder it needs taken out and put one level up
    Right I shall try that and Thanks
