Daz 4.20 Genesis 8F / Ellie Hair
Hi everybody...
I have a problem with Ellie Hair on Genesis 8 Female with Daz 4.20 (IRAY)
Without the hair, the render works well. But with the hair, i got black zone
Reinstall Ellie hair dont solve...
What can i do ?
758 x 1297 - 212K
  • Is your figure away from the origin? In Render Settings try chnaging the Instance Optimisation setting (if there are instances in your scene you want it to end up on Memory).
  • LeanaLeana Posts: 13,501
    edited March 2022
    Those marks are generally caused by the skullcap of the hair intersecting with the forehead of the figure. Making the skullcap a bit bigger (with morphs or a bit of scaling) usually fixes it if the settings change doesn't solve it.
    Post edited by Leana on
  • Hi Richard : Optimisation settings change result on the preview only (marks are less visible). But on the final render, marks are visible...
    Hi Leana : It works !
    Thank you
