change the texture
hi, how to change the texture once you load any basic g8 character? let say i make my own texture with photoshop so how do i apply new texture to my character?
    You would need to create a texture for each body part, matching the UV of the character. Then you would load those images in the Surfaces pane in Daz Studio.
    Load an existing Daz character, select it in the Scene pane, and then open the Surfaces pane and look at the images associated with each body part, to get an idea of the kind of images that are used for Daz character skins.
  • ho ok i see if i click on base color and i choose any texture it work perfectly but if i load any asset bough on store it don't work. is there another place to change skin texture other than base color?
    i bough this asset and i'm trying to modify all my textures for an single texture
    Irina Character Simple Skins Shader V2.2 - Daz Content by CG3 (renderhub.com)
    I'm not familiar with that product, but it looks like it has a video explaining it. Maybe that will help you. Perhaps someone who owns it will chime in. I suggest you change the name of your thread to "Need help with Irina Character Skins Shader".
    There are many image slots in a Genesis character's surface settings, not just base color. Like I said before, look at an existing character to see what kind of images are used and how they are used, or look for online character texturing tutorials. I am not an expert in that by any means.
  • TogireTogire Posts: 458
    When you have the character A selected in your scene and that you Ctrl-Click on another character B, you can select if you want to apply the morphs or the material of the character B to the character A.
    Have you tried this? Maybe this can solve your problem.
  • tanks you very much. both anwser fixed my problem.
    i load my single texture character then i load another character and i transfert my texture then i replace the texture by another one and everything work good. thanks you again and have a nice day :)
