i NEED TO RESET DAZ STUDIO TO FACTORY STATE
Hi there.
I have tried to enter a new shortcut in the customize panel and since then I cannot use Daz anymore, so many issues, menus that don't unroll, iray render gives a black image..,
can someone tell me how to come back to initial condition of the whole software?
I already have done "defaults", apply, but without any succes. tried several other things like uninstall-reinstall (twice!) no way it comes back with the same issues.crying
Thanks for your help.
  • PadonePadone Posts: 4,314
    edited February 2022
    It's not possible since the daz developers don't provide this option. You can do it but need to mess with the registry. Not something for normal people.
    basically:
    1. uninstall everything with the normal tools
    2. find all the leftover daz files on disk and delete them yourself
    3. find all the leftover daz entries in the registry and delete them yourself
    Post edited by Padone on
  • HogyoHogyo Posts: 59
    Thanks dear padone but you're not beeing of a great help.
    At least you know it can't be done. Not easily. Your best bet is to open a support ticket may be they will provide you more options that I'm not aware of.
    Thanks
    Well how do you do this:
    "find all the leftover daz entries in the registry and delete them yourself"?
    I search for "daz". Did it a couple times successfully but a long time ago since now I use daz studio only to export to blender.
    do you mean that you export your scenes to blender for rendering?
    Post edited by Hogyo on
  • IceCrMnIceCrMn Posts: 2,333
    I wouldn't recommend deleting things your registry unless you know what you are doing with it.
    You can do alot of damage fast.
    Should you choose to do so.
    I recommend you make a backup of it before you start deleting things.
    Sounds like you've got a couple common problems really.
    Adding new shortcuts to the main menus shouldn't make your renders all black.That's caused by other things.
    The new version of Daz needs the new GPU driver from Nvidia, or else your renders come out all black.Unfortunatly Nvidia are currently under cyberattack.So you really shouldn't download anything from there right now.
    There is current an issue with the new 4.20 general release version that won't save layouts also.Which is what I believe to be your "menus that don't unroll" problem.
    That problem has been fixed in the beta.You can get the release version to save your layout.There is a post here on the forum explaining how.
    I can't remember where it was at, so I'll have to hunt it down again.
    So the best questions right now are; What GPU driver version do you have installed, and what version of Studio do you have installed?
    Thanks ICE; I have just downloaded the last version of Daz:
    here are the GPU drivers details
    apport Informations sur le système NVIDIA créé le : 02/27/2022 20:19:17
    Nom du système : DESKTOP-TQ4H0S9
    [Affichage]
    Système d'exploitation :    Windows 10 Pro, 64-bit
    Version de DirectX :    12.0
    Processeur graphique :        GeForce RTX 3060
    Version du pilote :    461.72
    Type de pilote :    DCH
    Niveau de fonctionnalité Direct3D :    12_1
    Noyaux CUDA :        3584
    Resizable BAR        No
    Horloge principale :    1807 MHz
    Débit de données mémoire :    15.00 Gbit/s
    Interface de mémoire :    192 bits
    Largeur de bande mémoire :    360.05 Go/s
    Mémoire graphique disponible totale :    20441 Mo
    Mémoire vidéo dédiée :    12288 Mo de GDDR6
    Mémoire vidéo du système :    0 Mo
    Mémoire du système partagée :    8153 Mo
    Version BIOS vidéo :    94.06.14.80.18
    IRQ :            Not used
    Bus :            PCI Express x16 Gen4
    ID de périphérique :    10DE 2503 463019DA
    Référence :        G190 0060
    basically:
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/tech_articles/command_line_options/start - probably -resetDefaults or -cleanOnLaunch
    Thanks IceCrMn
    Downloading the new driver from Nvidia solved the black render problem.
    For the rest I adjust by using shortcuts.
    @Hogyo As suggested by Richard -cleanOnLaunch works fine here. Wasn't aware of this option since it's after 4.12 before I messed with these things myself. While -resetDefaults doesn't seem to work or it does other things. And yes I animate and render in blender with diffeomorphic, so only use daz studio to export assets.
    https://diffeomorphic.blogspot.com/p/daz-importer-version-16.html
