95% DAZer don't know it, when they facing a dark room
when you in a dark room in DAZ, almost everything can not be seen, what is your feeling? Panic? Believe everyone has the same experience before.
ctrl+L to turn on the headlamp? That is just a headlamp, not really lighting the whole room.
Well, DAZ has its default function to let you see everything in a dark room as normal, but most people don't know this.
It called ' !UberEnvironment2 Base ', search it in content library, and double click it when you in a dark room, then everything show up. I already put it in my script menu for convenience.
989 x 768 - 104K
  • All that does is load up a 3DL dome and distant light. Maybe just create a distant light?
    edited February 2022
    No, the UE2 adds global lighting that OpenGL understands, so AFAIK this is a good tip for IRay users to lighten up texture shaded view, just remember to delete or hide it before rendering.
    Post edited by Sven Dullah on
  • or make it invisible in render
  • scorpioscorpio Posts: 8,533
    I use an AoA light don't need to remeber to hide it or turn it off before rendering as Iray doesn't recognise it.
  • melaniemelanie Posts: 807
    I'm not sure if this is what you need, but this always works for me. Please see attached screen shot. Just click the little yellow lightbulb off.
    1000 x 563 - 65K
    Post edited by melanie on
  • glaseyeglaseye Posts: 1,312
    My preferred option is to use the 'AreaLight - HeadLamp Blocker' from one of Omnifreaker's UberAreaLights
  • marblemarble Posts: 7,500
    Yes that's the Preview Lights icon and the shortcut is CTRL-L ... that's what I use most of the time but I must admit that I hadn't thought of using 3DL lighting which would be invisible to IRay renders, I will give that a try too.
  • NylonGirlNylonGirl Posts: 2,368
    One time, I was in a completely dark DAZ room and there was a biguana in there. If it wasn't for my vinyl boots and bikini armor, I might have been eaten.
  • IceCrMnIceCrMn Posts: 2,333
    +1 ( we still don't have a like or thumbs up button for posts that make us smile and giggle a little)
  • Of course, when wandering into a darkened room, you also have to avoid getting eaten by a gru.
  • kyoto kidkyoto kid Posts: 42,403
    ..I just have a second (work) camera at the same location as the render camera with the headlamp on that I can switch to.
