Daz 4.20 no longer shows vRAM memory used
Tirick
Prior to the upgrade I would often use the information in the rendering details window to help plan out vRAM overhead, and 'budget' scene needs. I try to only render using the GPU and have disabled CPU fallback and CPU rendering. Normally, when my budget was exceeded, the rendering details window would still show some details of the memory used, but now it no longer shows even when the memory is sufficient and starts to render.
I can't recall there being a discrete setting to show these details, but I may be missing something. Is there a new setting somewhere?
Thank you,
Tirick
352 x 349 - 15K
This is a chnage in what Iray returns.
Ah, ok, thank you. I would be nice to have a native way to predict texture/geometry load in its stead. I presume there are some subtleties to it, and it wouldn't be as straightforward as just adding up all the file sizes on textures that are visible.
try baretail and open the log file, it updates the file in realtime by setting a refresh interval, keep baretail open during your DS use
not a prediction but you can see easily the amount of memory used, also gpu monitor like afterburner can give you the amount of memory used by the whole system
