Split screen issue on motion render
rpicone53rpicone53 Posts: 1
4.6 version. I can't figure out my motion render issue. Still renders are fine. Low res motion is split screen also. Is a re-load of DAZ necessary? Will I have to re-load all my content if I do? I seemed to have had this problem before and it went away. Windows 7. If the image can not load it shows a 45 degree line splitting from the right side of the window so the head is popping out the left side of the window at 45 degrees and the legs are coming in at 45 from the right side of the window.
863 x 710 - 83K
    Is this being rendered to an image sequence or to something like avi?
  • rpicone53rpicone53 Posts: 1
    Standard .avi. Any other render engines out there for this?
  • Richard HaseltineRichard Haseltine Posts: 112,059
    It sounds like a cocec issue - try using a different codec, or better yet render to an image sequence and then use a video editor to stitch it together.
