add a parameter to an object
BricabrakeBricabrake Posts: 5
Hello,
I need your help please.
Here I would like to add a parameter has a model to be able to open or close a door with a limit. But I have no idea how.
Can you point me to a solution?
Thank you for your answers, cordially.
545 x 485 - 53K
900 x 900 - 181K
900 x 900 - 177K
  • Richard HaseltineRichard Haseltine Posts: 111,390
    edited April 2015
    It's a little hard to follow your screen shots, but if it's just a standard transform or a morph click the gear icon on the slider, from the menu click Parameter Settings, and in the dialogue check Respect Limits and set the desired minimum and maximum values.
  • BricabrakeBricabrake Posts: 5
    Thank you but I have wanted to add like this
    545 x 485 - 62K
  • kaotkblisskaotkbliss Posts: 2,918
    Click the gear and open properties, there you can set the min/max values as well as the label for the parameter (should read "door" right now, just change it to "Open Close" or "Open-Close" or however you want to label it.
    Thank you very much it's ok
