Which color space does DS use for non spectral exr output ?
cgidesign
DS 4.16
Tonemapping = off
Spectral rendering = off
Render to 32 bit exr canvas (beauty)
What color space does DS use in this case?
E.g. sRGB, REC709, eciRGB etc.?
When spectral is on, one can decide in the drop down list, but not when spectral is off.
I don't think it is doing anything but linear RGB.
Your guess and my guess seem to be the same then.
Does an HDRI (exr) even have a colour space? I think the idea is that it encapsulates a full spectrum light environment of a scene.
I think the question originates from another thread in which we talked about the newly intruduced color profiles for spectral rendering.
They´re a good thing in the first place but the problem is that none of them look like spectral rendering did before which makes it difficult to use now without adjusting every single texture of an asset that contains color data.
I learned, the answer is no and yes.
No, it does not include a profile describing the color space.
Yes, openexr (maybe hdr as well) either contains information about the RGB primaries and whitepoint which indirectly tells about the color space or - if the info is missing - the spec. says to assume the primaries of REC 709 / BT.709 (which are the same in sRGB). If one is in an ACES pipeline the RGB primaries and whitepoint are different (the new spectral in DS seems to take care of writing the RGB primaries information via the new user choice). Knowing this, I now understand that simply importing an exr into the image editior of choice does not work. We need to know which primaries are in the exr and how the developers implemented exr import in their software. I have to investigate further.
The other question is the gamma curve. There it is more clear. EXR is linear. So, when final output is REC709 then gamma 2.4 is the one of choice, when sRGB then 2.2 (not exactly but near to that).
Does anybody know of a tool to read the RGB primaries and whitepoint from an exr file? I searched the net but no luck.
EDIT:
Ok, Fusion in Davinci Resolve can show the exr metadata.
Now we know that DS 4.16. with spectral off is writing sRGB / REC.709 primaries and REC.709 gamma 2.4. So, DS is writing REC.709 metadata not sRGB as I initially thought.
What I don't know yet is, what does Affinity Photo's color managment do with this information? Its default color space for 32 bit images is ProPhoto which has different RGBprimaries than sRGB or REC.709.
I have a few EXR applications, I will try and check if any of them work with what you described.
You posted before i finished editing
But I am curious what your tools tell us.
