Creating a eraser plane or object?
Is there a way to create an eraser plane or object?
Like when you turn the sky off in Daz it creates a checkerboard pattern that is a transparenecy in the render.
Can this same checkerboard be applied to objects as well?
  • felisfelis Posts: 6,490
    You can create an Iray section plane node and hide anything behind, so it will be transparent.
  • EZ3DTVEZ3DTV Posts: 1,621
    Hmm, that sounds interesting Felis, I will look into that thanks!
    I was trying to think of a way to leave the HDRI sky on, but still get a gray transparency background front facing my camera.
    The plane seemed like a possibility I could maybe make the plane in front a unique color and key it out later in photoshop.
    Or maybe use canvases in some clever way.
