vanishing Strandbased hair in animation
WendyLuvsCatzWendyLuvsCatz Posts: 41,714
edited February 2022 in Daz Studio Discussion
does anyone else have vanishing strandbased hair in animation?
In particular using Filament with PBR visibilty all options and line tessalation 3 viewport and render
but it often does it using iray too if just visible in render, the initial frames render but after a few hundred it just stops rendering
Filament frame 1
frame 513 still has hair
514 onwards it is gone
3840 x 2160 - 3M
3840 x 2160 - 3M
3840 x 2160 - 3M
  • How about if you do a still render of those frames, if that is not what you are showing? Have you checked that none of the hair properties are keyed?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,714
     no, it does it consistently with Filament,
    iray not so often but iray is very slow, I did render 30 frames the length of the animation with iray and they all had hair
     the filament one of the same poses was 1K frames as I changed the framerate to 1K fps
    maybe it does not like huge frameratessurprise but I have had it happen 30fps too, they are image series
    a video with Flowframes interpolation between the 30 frame iray slideshow, she kept her hair, this is of course extra slow, my Filament animation was 30 seconds
    I overwrote it sadly as was annoyed
    OK I found an iray one
    Dec 2020 so thought it was because Dforce hair still newish
    but it never got better cheeky
    I don't use it very often
    I did get 500 frames today with the Tara hair but thats still a very short animation
  • Please flag it via a report, attaching the scene file with a note of the content used.
    sadly I overwrote it
    I just wanted to get an animation done, stuck a hood on her instead
    I would be interested to know if others have experienced this
