Is this toon shader set still usable in 4.15 Pro? If so, is it a PITA to use?
http://www.daz3d.com/visual-style-shaders
  • GordigGordig Posts: 10,803
    I used it in 4.16, so I'd imagine it works in 4.15 as well. I find it rather easy to use, but I haven't spent much time with it.
  • HylasHylas Posts: 5,328
    edited February 2022
    I used it recently-ish (in whatever was the latest version of DS in October 2021) and liked the results quite a lot.
    I found it a little tricky to use, but that might have also been because it was my first time rendering 3DL.
    I had to read the instructions first and re-read to them a few times while working.
    Post edited by Hylas on
  • rillarilla Posts: 57
    You have to study the manual. It's really good in explaining how to use the shader. It definitely works in 4.15. I use it daily. The best thing is to experiment and then build presets. I love VSS.
  • WillowRavenWillowRaven Posts: 3,787
    Thanks, all. Sometimes grabbing older stuff is risky, so wanted to make sure before adding it to my wishlist :)
