How can I get a transparent background in iRay?
AdrianSAdrianS Posts: 77
I've been fiddling with the new iRay engine and I'm basically impressed, but it's complex and there's not much instructional material as yet. My main issue is this. I usually render individual figures, with no scenic elements, as I prefer to add backgrounds in Photoshop. Although the render engine produces a pdf file, the background of all the renders I've done so far is black, not transparent. Am I missing something?
  • Richard HaseltineRichard Haseltine Posts: 111,696
    edited April 2015
    Turn off Draw Dome and Draw Ground under Environment in Render Settings.
  • AdrianSAdrianS Posts: 77
    Thanks - that did it. I'd tried turning off the dome, but hadn't turned off the ground.
  • gibson.johnny3gibson.johnny3 Posts: 25
    Choose scene only that should only render the content you have added :-)
  • Leave Draw Ground ON if you want shadows. This will not effect transparency.
