Where are Genesis 2 Morphs and products installed and Is there any Documentation on how to use them?
nokoteb99nokoteb99 Posts: 943
I bought these:
Genesis 2 Female Body Morphs
Genesis 2 Female Head Morphs
Victoria 4 for Genesis 2 Female
Genesis 2 Male head Morphs
Genesis 2 Male Body Morphs
Michael 4 for Genesis 2 Male
V4 Skins Auto Converter for Genesis 2 Female
Michael 4 Skins Auto Converter for Genesis 2 Male
I know where the Skins auto converter are.
But where the heck is the Body and head morphs? When i bought V4, they would be in a folder then i would have to press a button to install them into V4. When i got M4...i loaded M4 and then i got a window asking me if i wanted to install the base and the ++ morphs into M4.
But how about the ones i bought for Genesis? Where are they?
WHen i click on a Genesis figure and see the parameters listing, i do see stuff like morphs but they don't seem to be as many as the ones V4 and M4 had. Are those that i see in the parameters, the ones that got installed into the Genesis figures automatically when i installed the Gen 2 Female Head/Body Morphs and Gen 2 male Head/Bdody morphs?
    Anywhere that you see this statement on the Product Page:
    This product contains only new shapes for Genesis 2 Male(s), there are no user-facing files.
    That means that there are NO files to be found in your Content Library or Smart Content, ONLY in the Parameters Pane.
    Make sure that you have the figure selected, then go to the Parameters Pane to find the appropriate sliders.
  • Mostly HarmlessMostly Harmless Posts: 25
    edited April 2015
    Morphs for Genesis (which includes Genesis 2 male and female) based characters are not injected like they are for Gen 4 characters. All morphs are either included in the parameters tab under actor, or under the shaping tab, when a Genesis based character is loaded. Also, expression and morph-form type movement morphs can be found under the poses tab, under actor and pose controls.
    There may not be as many morphs with the packages you've purchased, but they can be combined easier. There are also other morph packages, such as the Morph Resource Kits by Handspan Studios and Thorne, for even more combinations.
    Genesis 1 Morphs are not directly transferable to Genesis 2, as there are changes to the base mesh. Genesis Generation X2 can transfer those morph, though if will require GenX2 AddOn for Genesis 2
    Post edited by Mostly Harmless on
