where to find sliders for aging-morphs-for-genesis
The 8 icons for the body shapes are in the library but I see no new sliders for the face in parameters-if I put any word from the product's funtion such as "Ear Age" nothing comes up either
https://www.daz3d.com/aging-morphs-for-genesis
  • LeanaLeana Posts: 13,583
    Did you select the whole figure or just the head?
  • VicSVicS Posts: 1,273
    I tried both  ways
  • MelanieLMelanieL Posts: 7,878
    With the figure selected, they should appear under "Actor" - "Aging Morphs" (in both the Parameter tab and the Shaping tab)
    Thanks but they're not showing up
    I presume you used DIM to install? Are the morphs present in you library - if you open DIM and right-click the aging morphs entry and display installed files, does it have the expected list of morphs?  If you click on one of them in that insatlled files list, does it take you to your content library data/DAZ 3D/Genesis/Base/Morphs/Zev0/Aging/... ?
    ok i forgot, ill reinstall through DIM and let you know, thanks
    It works now, it's under actor/aging morphs/head-thank you!!
  • Jim EadonJim Eadon Posts: 17
    Admins, please could you file this as a BUG in Daz Central? I was wasting time troublshooting this issue, where the solution is to re-install using DIM.
    To the contributers, thanks, life saver :)
  • Richard HaseltineRichard Haseltine Posts: 111,726
    Install method shouldn't matter in that way, but if you are finding that ti does you will need to make a report - a Technical Support ticket - as it is not something we would be able to answer questions about.
