A quick question about AniMate Lite
Ok, so I just started to play with the animate lite, and I suspect the answer I'm going to get is no, but I just want to make sure.
I'm playing with some of the dancing blocks, and would like to switch lights on and off at certain points, is this possible to set up in animate lite, or am I going to have to run it for each light and splice them elsewhere? It seems like I can only have one character in the timeline but might be missing something obvious.
As far as I am aware, Animate Lite is limited to simply 'using' the supplied Aniblocks.
I think you need the full version to save and edit your own Aniblocks. http://www.daz3d.com/animate2
I suspected as much, but I sometimes miss the obvious. Luckily, for what I want to do, it only takes 15 minutes to run the render. So I set the lights up, and run one set with one color, then turn that one off and the next one on and re-run. Takes a little longer to then splice them together, but for now it'll work.
