Could not find file....
I'm the beginner. I downloaded and installed Viviy figure that I bought in Daz store by using Daz install manager but it says "Could not find file..." as the attached pic2 and also tried manual downloading, however it still says "Could not open file...". Does anyone know how to fix this error. Thank you.
2113 x 1496 - 153K
2118 x 1466 - 292K
2122 x 1476 - 300K
    It's probably because of the non-english characters in the path.
    Having your content on onedrive is also not a good idea, but doesn't prevent DS from seeing the content.
  • GordigGordig Posts: 10,833
    Actually, the problem appears to be that they installed through DIM, but DS is looking for the files in the Daz Connect folder.
    Missed that...
    That means the product is also installed within DS with DAZ Connect, but the problem is probably still the non-english characters in the path.
  • jjoynerjjoyner Posts: 882
    edited February 2022
    On a few occasions, I have found that after I installed a product (oftentimes a manual install of a free item from another site) and then tried to open the product in Daz Studio, I would get a similar file not found dialogue box.  In most cases, I discovered that the vendor had either placed a file in a location other than where the product was looking to find the file or the file was missing altogether.  Site mail usually clarified the situation if I could not correct the file location issue by manually moving the file to where the product needed it.
    Post edited by jjoyner on
