Viewport shows blank between copied and pasted frames.
This is a problem I've had for a couple times now.
While i'm trying to create a simple animation with my figure, I copy a frame on the timeline, paste it further down, then when I play the animation it shows a blank display on the viewprt between the frames.
What could this mean, and what do I do??
  • Copy and paste can do odd things, unless it has been fixed - and I don't recall anything in the change log. (Just checked the Public Build, the behaviour is unchanged.). If you look at the graph in the Timeline you will probably find that the values shoot off to infinity and then come back down, producing the blank frame since the object is way out of sight.
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
