Textures: V4 to G2M [Solved]
Atticus Bones
Yes, you read correctly. I'd like to apply a skin texture with Victoria 4 UVs to a Genesis 2 Male.
Is there any way that this is possible?
Post edited by Atticus Bones on
Did you happen to get the K4 UV maps for G2F and G2M Christmas freebie?
If so...load V4 skin on to Genesis 1, use the Map Transfer, in Studio to transfer the maps to K4...then load them onto G2M...set to K4. From there you can either leave them or swap them to G2M by going another round through the transfer.
If not, you'll probably need to get the V4 UV maps from the store and use something else as an intermediary transfer point.
Thank you! Map Transfer's exactly what I was looking for.
I think it's a brilliant idea! I also got the UV freebie, but trying a female skin on a male should be interesting!
There are some V4Male textures ...
