Things already d/l & purchased reappearing in d/l tab in DIM?
HorusRaHorusRa Posts: 1,665
edited February 2019 in New Users
Post edited by HorusRa on
    That sounds like the ManifestFiles folder is losing files. Are you using the default locations for everything or have you customized them? Is it possible you're having hard drive problems?
  • HorusRaHorusRa Posts: 1,665
    I don't know why Spybot would find those files suspicious, unless it was a pure reputation-based analysis, but that sounds like the culprit. See if the .dsx files from the ManifestFiles folder are in Spybot's quarantine.
    Also, in DIM go to Settings > Installation, right-click on the content location, and choose "Fix Installed File Registry" -- that will correct DIM's record of files that were present before DIM installed them.
  • kaotkblisskaotkbliss Posts: 2,918
    If there's an update to a product (smart content added, texture tweaked, name edited, etc) then the product will go back into the DIM to be re-downloaded (But usually has a category title above them saying something like "Updated Products")
    If it were a product update it would still show in the Installed tab also. Spybot still sounds like the likeliest cause.
