Error after loading Aiko 6
Daniel BarnettDaniel Barnett Posts: 389
Just purchased Aiko 6 and tried to load her and I get the following error in the log file. All help is appreciated!!
dbb
*** Scene Cleared ***
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Gia/FBMGiaBody.dsf#Gina_Body?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FSocks_Gia.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Girl 6/FBMGirl6.dsf#FBMGirl6?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FSocks_G6.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Gia/FHMGiaHead.dsf#Gina_Head?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FNoseGone-Gia.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Girl 6/FHMGirl6.dsf#FHMGirl6?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FNoseGone-G6.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Gia/FHMGiaHead.dsf#Gina_Head?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FNoseBump-Gia.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Girl 6/FHMGirl6.dsf#FHMGirl6?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FNoseBump-G6.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Gia/FHMGiaHead.dsf#Gina_Head?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FEarGone-Gia.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Girl 6/FHMGirl6.dsf#FHMGirl6?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FEarGone-G6.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Gia/FHMGiaHead.dsf#Gina_Head?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FEarBump_Gia.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Girl 6/FHMGirl6.dsf#FHMGirl6?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FEarBump_G6.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Gia/FBMGiaBody.dsf#Gina_Body?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FCleavage_Gia.dsf
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Girl 6/FBMGirl6.dsf#FBMGirl6?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/RawArt/Raw_G2FHero/MCM_G2FCleavage_G6.dsf
WARNING: fileinput\dzassetdaz.cpp(5450): Duplicate formula found linking YRotate & G1_CTRLNeckHeadTwist in /data/DAZ 3D/Genesis 2/Female/Morphs/D3D Gen X/Genesis/G1_CTRLNeckHeadTwist.dsf.
WARNING: fileinput\dzassetdaz.cpp(5450): Duplicate formula found linking ZRotate & G1_CTRLNeckHeadSide-Side in /data/DAZ 3D/Genesis 2/Female/Morphs/D3D Gen X/Genesis/G1_CTRLNeckHeadSide-Side.dsf.
WARNING: fileinput\dzassetdaz.cpp(5450): Duplicate formula found linking XRotate & G1_CTRLNeckHeadBend in /data/DAZ 3D/Genesis 2/Female/Morphs/D3D Gen X/Genesis/G1_CTRLNeckHeadBend.dsf.
WARNING: fileinput\dzassetdaz.cpp(5450): Duplicate formula found linking Value & G1_CTRLBrowSqueeze in /data/DAZ 3D/Genesis 2/Female/Morphs/D3D Gen X/Genesis/G1_CTRLBrowSqueeze.dsf.
File loaded in 3 min 51.8 sec.
Loaded file: Aiko 6.duf
Loaded Morph Deltas in 0 min 0.0 sec.
Loaded file: FHMAiko6.dsf
Loaded file: FBMAiko6.dsf
Loaded file: PBMNavel.dsf
Compiled C:/Users/Owner/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
stdin: in function shader_Displacement
stdin:438: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
stdin:454: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
Compiled C:/Users/Owner/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
  • Richard HaseltineRichard Haseltine Posts: 112,037
    The could not find target warnings are not errors - they just mean that Aiko 6 includes correction or other adjustment morphs that hook up with the other shapes, if you have them. Since you don't have them they aren't needed, but the log records the failure in case it isn't benign and needs to be tracked down.
    The duplicate formulas is probably harmless, but if they are morphs you transferred with GenX it may be worth checking to see if there's an updated version of the plug-in.
  • Daniel BarnettDaniel Barnett Posts: 389
    Thank you!
    dbb
