Advise me how to get rid of this dark line around the lips (g8m) please!
Advise me how to get rid of this dark line around the lips (g8m) please! A long time ago I quite accidently found a way but had to do it only once and forgot how I achived it.
972 x 890 - 2M
  • KainjyKainjy Posts: 916
    You are using a lips material not from the same skin product.. choose a bundle and use skin and lips from the same product/character.
    If you want to use both, you have to manually fix the lips texture (by Photoshop)
  • SpaciousSpacious Posts: 481
    If the above answer is not your situation, then perhaps you've changed the translucency settings for the lip or face materials.  The solution above will then help to get you back to the materials you started with and you can make sure you change them in the same way this time.
  • barbultbarbult Posts: 27,631
    If none of the above was the case, maybe the product textures were made poorly. If you name the product you are using, other owners can check to see if they have the same problem.
    If you copy the face material to the lips, there shouldn't be any difference anymore.
    Thanks!
