Hands and Thighs Are Way Too Big!
Boingo the ClownBoingo the Clown Posts: 97
I want to use Genesis to make game sprites for a boss the player has to fight against.
I wanted the boss to be muscular and threatening, with a torso filled with big exagerated bulging muscles. I applied the body builder morph to Genesis, butit was not enough. I also have the Generation 3 morphs for Genesis. I applied the Freak 3 morph to genesis, but it still wasn't muscular enough to be intimidating. I then tried both morphs in combination. That finally gave me all the upper body bulk I wanted, but both morphs enlarged the hands and the thigh muscles.
Now I have a guy withabsurdly large hands and thighs the size of beach balls.
Is there a way of applying the morphs only to the upper body to avoid this?
Is it possible to select just the body parts I want morphed and export the morphs, thereby making my own morph that applies only to those body parts?
    Select Genesis. Go to the Parameters Tab, on the Left, look for "Actor".
    You can select different sections of the body to apply different morphs for.
    Certain morphs can affect more then one part of the body but only if its designed to.
  • Boingo the ClownBoingo the Clown Posts: 97
    I just gave it a try and selected only the parts I wanted effected.
    It did not work. The bodybuilder and Freak 3 morphs are applied to the entire figure, not just the selected parts.
    Do you happen to have the Genesis Gorilla?
    Sickleyield's conversion of DieTryings morphs have several thigh morphs that do go negative.
    http://www.sharecg.com/v/58198/gallery/21/DAZ-Studio/DieTryings-182-V4-Morphs-for-Genesis
    This is Bodybuilder at max, Gorrila 15%, and DieTrying's thigh morphs used to dial back the thighs...then I played around a little with other DT morphs to give him a 'rugged' face. He's using Phoenix1966's Thomas.
    800 x 800 - 352K
