Conforming M4 and V4 clothes to body morph
I still haven't been able to get this to work, we tlaked about it in another post but I dpont think it was the header at least I could not find one, so does someone have a good way to for example make the belly fat and ot have figure poke throught the clothes?
  • Are you right-clicking and selecting Transfer Active Morphs?
  • VicSVicS Posts: 1,273
    yes
  • and is it not working at all, or not having the desired effect?
    yes, I SELECT THE ARTICLE OF CLOTHING THAT NEEDS TO BE CONFORMED THEN RIGHT CLICK CORRECT?
    1098 x 1053 - 2M
  • BejaymacBejaymac Posts: 2,002
    The reason nothing is happening is that the morph(s) already exist in the clothing, and Transfer Active Morphs wont replace an existing morph.
    The reason the morph(s) don't work is likely down to a little thing called Poser Cross Talk, the ERC code is made in such a way as to avoid this from happening, this however leaves DS users with buggered ERC and morphs that don't work.
  • KainjyKainjy Posts: 913
    Try with collision Iteraions...
    If you don't have it in your clothing parameters, add a smoothing Modifier (https://www.youtube.com/watch?v=QILf-QJBhEY)
    You can also add a Push modifier to pull out the dress (https://www.youtube.com/watch?v=TwKcEGdIXLI).
    Ok thanks for the tips I could use those
