Bought a new texture product; Can't find it
I used the search filter, buy using the words, texture, bricks, texture resource bricks, and it won't find the product.
I've searched under environments, materials, props, scene builder and under the ALL option.
I've looked under Files and under Products.
I've searched on the left side and on the right.
I've searched using the artist's name, and I've searched using the SKU #.
SKU:18789
Artist: DAZ Originals RajRaja
Nothing.
Can some kind, experienced DAZ expert help a guy discover what he's doing wrong?
Thanks in advance.
Aaron
It's a resource texture... That means it's not meant to be applied directly to a product, but you are supposed to create your own texture file from it, which you can then apply to your structure.
You will find the files in your content folder under
/General/RajRaja/TextureResource-BRICKS/
though not within DAZU Studio.
You can find the fill file list here:
http://docs.daz3d.com/doku.php/public/read_me/index/18789/file_list
Texture resources like this only give you the texture image files. Normal texture sets also give you the DAZ|Studio script files — these are the only parts of the texture set visible in your content — that load the textures and apply them to an object in your scene, at the same time setting all the relevant surface parameters so it looks good when you render. With a resource set, you have to set up the surfaces manually, then save the material scripts.
