Way to copy things?
ToobisToobis Posts: 993
When you create primitives and put them down is there a way to copy the exact same thing you just spend a while creating and making as many as you want of the same primitive with the same dimensions?
ty.
  • Richard HaseltineRichard Haseltine Posts: 111,516
    The Create primitive should remember your settings, and should remember sizes and divisions separately for each shape.
  • SlimerJSpudSlimerJSpud Posts: 1,456
    When creating props using Daz primitives, I find the best way to save them for reloading is to get rid of everything else, and save them as a scene. You can merge that scene (File>Merge) into whatever scene you are working on as many times as you want, but there is no built-in way to clone one item many times. Isn't there a 3rd party product called Send in the Clones? You can also export it as a Poser format prop and put it in your library.
