Saving Harddrive space
SInce installing Daz I've lost a huge amount of harddrive space on my Mac which has relativly small harddrive space to start of with.
How can I move the assets I'm not planning to use sometime soon from my computer onto a harddrive? I've bought and downloaded some freebies for projects that I'm not currently working on and would rather have the scratch disk!
You can uninstall Daz content, and content from third parties that is set up for Install Manager. If the content was manually installed then your only option is to look at the zip as a guide to the file placement and then manually remove the files (the textures will probably account for the lion's share, and should be easy to remove - presets and morph assets are relatively small, though the latter do have an impact on load times for the base figure).
