Problem in adding clothes help please
danieldarknetdanieldarknet Posts: 21
I was using daz usually when I add my clothes model the following happens when I add a piece of clothing she will more normal when I add another piece it replaces the one I had already added, it happens to all models, as I resolve that someone can help me please, since reinstalled the program and zeroed the record further still with this problem ??
Sorry for my English I am Brazilian
Daz Version 4.7
  • BeeMKayBeeMKay Posts: 7,019
    Is the old piece of clothing you add visible in the scene tab? If yes, when you click on the eye in front of the new piece of clothing, is the old one visible again?
  • danieldarknetdanieldarknet Posts: 21
    Not when I add the garment she removes the previous one and one-piece. the list of objects.
    I made a video showing
    the error that clothing replaces the piece added already uploaded the video a moment I've ever post.
    edited April 2015
    This makes it easy to understand where the error is cursed.
    Does anyone have solution for this ??
    Post edited by danieldarknet on
    Did you do anything special before this began to happen?
    I was creating metadata, give when I was using was this already deleted the metadata that I had created but not yet decided.
    Does not have any way to reset 100% Daz to return the factory settings ??
    edited April 2015
    I don't think it is a DAZ Studio problem.
    Does this happen with all clothing, not just the Crazy Belle items?
    Have you tried loading these items from the Content Library pane and NOT from Smart Content?
    Post edited by JimmyC_2009 on
    Updated Video:
    https://www.youtube.com/watch?v=xNHsL6akavY&feature=youtu.be
    More enlightening, it happens all the clothes and even the library list
    edited April 2015
    This problem started after I click
    Do not show this again
    The image on the link below
    Panel Chooise Image
    edited April 2015
    Thanks for the updated videio, though I'm afraid this goes way beyond my knowledge.
    Okay... according to the error messages it throws in the video, it is trying to create something called a "Circular ERC".
    Maybe it's best if you submit a help request here: https://helpdaz.zendesk.com/requests/new so that someone of the DAZ people takes a look at it. Also iunclude the information about changing the meta data before this started to happen.
    Though, with the weekend, it might be until Monday before you get an answer.
    Look for this folder (This is in Windows 7, I don't know where it is elsewhere):
    C:\Users\YOUR\AppData\Roaming\DAZ 3D\Studio4
    There's a "log" file in it. You can open it with the text editor to see what it contains.
    Attach it to the error report.
    Or you can look for a message about how the program tries to apply the clothing item when the other one vanishes, and then post the message here.
    (Oh, and if you want to delete DAZ Studio completely before setting it up again, this folder also has files that need to be deleted.
    Don't delete C:\Users\YOUR\AppData\Roaming\DAZ 3D\cms as it contains the data base. If you delet that one, you will have to reinstall your content.)
    Post edited by BeeMKay on
    edited April 2015
    Panel Chooise Image
    Ah... if you get that, select "Do not replace" option. I think it now is set to replace everything. I have marked it with the arrow.
    If you don't want the panel to show again, select the second option I circled.
    Then try again.
    472 x 550 - 40K
    Panel Chooise Image
    Then try again.
    But as I open this panel, it does not appear this so I can change the options?
    Which tab is it ??
  • Richard HaseltineRichard Haseltine Posts: 112,099
    edited April 2015
    You need to turn it back on - Edit>Preferences>Content Library>Replacement Management, set the option to Ask
    434 x 296 - 30K
    Many thanks to all who helped work out here, after uninstalling and reinstalling a lot of times I learned one more thanks again.
