genesis 2 materials to genesis 1
Hi,guys; as the topic title says i'd like to know if there's any way to use a genesis 2 material on a genesis figure
thanks
thanks
This is the only way I know of : http://www.daz3d.com/genesis-2-male-and-female-base-uvs-for-genesis
it can't be done manually?
Since Genesis came first, it was not UV Mapped for Genesis 2, just V4, M4 and Kids 4 (along with the Base Genesis)
In other words, the only way to apply a G2 skin to Genesis is to have the UV Map,, or make one yourself. It is no simple matter.
Also bear in mind that Genesis is both Male and Female.
mmm i see....i should try to create the uv map from a genesis 2 male figure in zbrush
You can also use Map Transfer to convert the G2 maps to V5/M5 (assuming you have those UV sets for Genesis 1).
how??
Have a look at this until Mike is able to reply
http://kaos3d.deviantart.com/journal/Daz-Studio-4-Map-Transfer-Mini-Tutorial-303888794
