Victoria 4 for Genesis 2 Female help
deeahr2169deeahr2169 Posts: 497
Ages ago i purchased Victoria 4 for Genesis 2 Female by Mallen Lane. I hardly used it because i began to find G2F so good i didn't need to. Now though i would like to use some V4 characters and want to have the added flexibility of the G2F. I cannot find any info on how to use the V4 for G2F product, can anyone help me find some documentation please...
  • R25SR25S Posts: 595
    inside DIM go to installed and type in the searchbar "Victoria 4 for Genesis 2 Female" then use the "i" Button
  • LeanaLeana Posts: 13,501
    V4 for G2F adds 3 things to G2F: a V4 shape morph, a V4 autofit clone to convert clothes, and the V4 UVs.
    The V4 UVs enable you to use V4 textures on G2F. You need to resave the material files as .duf files first though, as the name of the material zones is different between V4 and G2F: a .duf preset will convert them automatically when you use it, but other preset formats can't.
    If you plan to use a lot of V4 texture, there are utilities available in the store to do batch conversion of older presets or use older presets directly.
    V4 for G2F won't give you the ability to use V4 morphs though. To convert morphs you need the "Generation X" program (in the store).
  • edited February 2016
    I applied the V4 UVs and adding a V4 texture in Poser is doing nothing. So you are saying I need to convert that texture in DAZ? If I do that though how do I get the specific SS settings/nodes in Poser that are part of the original V4 material settings? Because I used the blacksmith texture converter originally and had that problem, that the nodes were all wrong.
    Post edited by scullygirl818_02147fecb6 on
