A daz account can be put on more than one machine?
If I have a second machine, provided my account with all it's stuff can be put on both machines, can they also both be used at the same time, both running oiff the one account?
  • Yes you can install on both, but I don't think the license allows concurrent uses.
  • VicSVicS Posts: 1,273
    ok  thanks, do you know where I can I find out for sure becasue I was considering doing that if it could work.
  • cgidesigncgidesign Posts: 442
    I don't know about running the software on two machines.
    But be aware that only you can use the content and the software. You can not let anybody else use your account to download and use your content. That's even true when the other person sits next to you in front of your second computer.
    https://www.daz3d.com/eula
  • Looking at some of your other threads, do make sure that you are the person using the application - you can't sub-license to another person.
  • LeanaLeana Posts: 13,593
    You don't need to log into your account to use the program, only to install content. Installing at the same time on both machine will probably not work, you'd have to install on one then the other.
    Running DS on 2 computers at the same time so you can work on a scene on one machine while you render another one on the second machine for example would be OK. Having someone else using the content on the second computer would definitey not
    Ok that's good-just to be sure I understand....I will have all my content on both machines, they are both opened up with daz running, while I am rendering on one machine I am able to use the other machine for more daz work-it has nothing to do with anyone else it is only for me-this is A-OK?
    edited January 2022
    Well that used to be allowed in the past at least. I would need to check the licence in the installer to be sure...
    I'll look tonight if no one has the answer before.
    Post edited by Leana on
    Thanks Leana
