What exactly do each of the genesis textures connect to?
I see 4 different files i see the base texture which gives us skin and the like and i see 3 other ones denoted with a 'B' an 'S' and an 'SSS' what do each one of them indivudual do I'm trying to understand this especially when say importing into Maya where i have to redo all of the textures I would need to know the correct place to plug them but the naming convention is definitely a little different than what I'm used to. Thank you guys.
  • LeanaLeana Posts: 13,502
    SSS would be subsurface scattering.
    B is often used for bump maps, and S for specular maps.
  • GordigGordig Posts: 10,799
    I don't know if Daz SSS maps would be any use in Maya, as they're typically just lightened versions of the diffuse map, if even that.
  • docbotherdocbother Posts: 108
    Why not load the material onto the figure and look at the "Surface" panel to see how they are used?
