Duf and other file pictures aren't accessible
rampart_1576840087
Here are a few screen captures...
I used DIM to install the content items.
There is constant message the file doesn't exist where there is no picture showing.
Yet, in the windows explorer folder the files are there.
I think there is something I must do to get the content management or smart content, etc. to work properly.
1089 x 800 - 290K
1061 x 791 - 304K
1064 x 839 - 330K
The items in question have a (2) in front of the name, which means there are two files being referenced. Try doing a "Scan Known Directories For Files" -- if that doesn't remove the duplicates, Export User Data, then Reset the database, then Re-Import Metadata.
The folder you installed to is not set as a DAZ Studio content directory. If you download and run thisscript http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start it will add the install manager directories to DS for you.
